1978 - 1996 Big Bronco
Defroster Problem
Old Nov 13, 2002 | 10:09 AM
gruveb's Avatar
gruveb
Defroster Problem
When I was working on the tailgate window switch, apparently I messed up the vac lines that operate the defroster, vent, floor and mix vents.
All of them seem to work except for the defroster. I've checked, and it looks like everything is hooked up.
What should I check? It did work before.
I have an 83 Bronco XLT.
Feeding my 9 mile a gallon habit.
Old Nov 14, 2002 | 06:00 PM
steve83's Avatar
steve83
Defroster Problem
Remove the glovebox (you'll need a stubby phillips screwdriver - you don't have to remove the door) and look inside the dash for the defrost vacuum motor. Then trace its hose (by color) back to the mode select switch and look for breaks. If you have a MityVac, you can test the line & motor.
While you have the glovebox out, look on your firewall for a CB antenna combiner. It would be close to the R A-pillar near the windshield.
Old Nov 14, 2002 | 06:33 PM
JBronco's Avatar
JBronco
Defroster Problem
Just wondering why the previous poster told him to look for the cb antenna combiner. Also, is this something Broncos have, and if I put in a cb I can use the regular antenna?
Old Nov 14, 2002 | 07:19 PM
bronco cam's Avatar
bronco cam
Defroster Problem
Cb antenna combiner? Steve tell me what this is or what to look for.
Old Nov 15, 2002 | 09:09 AM
Pantherchuk's Avatar
Pantherchuk
Defroster Problem
do people still use CB's??
HAM RADIO on RYE please....
just kidding - each and his own.
Old Nov 15, 2002 | 10:06 AM
gruveb's Avatar
gruveb
Defroster Problem
I'll tear in there and look. I know it has to be something that I disconnected because it worked before.
My Bronco came with 2 antennas. One for CB one for radio.
HAM radio is superior, but who wants to be that geeky
Feeding my 9 mile a gallon habit. Just kidding. I actually want to get "into" HAM, just haven't had time.
ONe other question. The flap that closes the heater compartment off from the rest of the vent system is stuck open. I tried moving it with my hand and it won't move. What gives?
Old Nov 15, 2002 | 11:36 PM
steve83's Avatar
steve83
Defroster Problem
The CB combiner was installed in the regular antenna cable on trucks with the factory CB option. It's rare, but I've found it in 2 Broncos in junkyards. It was merely curiosity that made me ask about it.
gruveb
Your blend door has probably broken off its hinge & gotten cocked inside the duct. Or it could be that the cable broke inside its sleeve & has jammed the door.
Old Nov 16, 2002 | 03:55 AM
Mudinyureyes's Avatar
Mudinyureyes
Defroster Problem
