Does anyone have a accelerator assembly?
Old Feb 17, 2007 | 02:58 PM
truckfarmer's Avatar
truckfarmer
The stock pedal assembly is pot metal and tends to break easily. I have found that a pedal assy from a 73-79 Ford truck will bolt into the 53-56's by opening the bolt holes a bit. Depending on which donor truck you use, it may have to use a solid rod to the carb or some of them had a bracket on th efirewall to be able to use a cable. This pedal assy also does not mount to floor at the bottom but is a floating pedal.
tip49
Mar 5, 2008 05:54 PM
BOBBY6931
1997 - 2003 F150
Apr 30, 2007 04:23 PM
bobbyngeorgia
Oct 12, 2005 11:56 AM
bobby d
Dec 5, 2004 07:36 AM
bobby d
Dec 4, 2004 08:34 PM
