Hey All... I have a 06 F350.... and for some strange reason today lost both right side turn signal functions and brake light... left one work fine.. stopped by local dealer to have it checked out.... well after about a hour of jackn with it they admitted they were bamboozled.... anyone else have this sort of dilemma before?? Thanks...
If you have a two bulb taillight, one backup and one for the rest. The brake and turn are on the same filiment. I would start with replacing the bulbs, it could be shorting. I would also try pulling the bulbs one at a time to see if function returns.
Yea... the bulbs have been replaced.....and a voltage check at the plugs....which have none....and I forgot to mention that the trailer plug connection also has the same malfunction.... I did a lil checking on the switch last night.. and revelled 2 hot wires feed.. and 2 wires out-going flashing on the left turn mode, but zilch for the right side.... but its hard to tell whats-sup w/o a diagram plus its cold outside......
