??? Overflow Tube ???
Old Feb 14, 2007 | 02:15 PM
T.J.Hooker's Avatar
T.J.Hooker
2001 Sport ??? Overflow Tube ???
Hi All,
I have a 2001 explorer sport with the 4.0L . I live in upstate NY. This morning I started the car, then left, but had to come back as I forgot something. We're in the middle of huge Nor'easter right now, and the driveway is full of snow, so I parked in the road, and ran into the house. On my way back to the car, I walked by where I had it parked before leaving. I noticed a green, coolant looking spot in the driveway about 3-4" around. I was dumbfounded because the position of the spot under the car, looked like it had to have come from the transmission area. It wasn't a big spot, and the car wasn't overheating, I had plenty of heat, everything was normal. When I returned, I backed into the driveway through about 10 inches of snow. There was a little green in the snow I scraped over with the bottom of the car. After a little while of shoveling around the car, I crawled underneath, and took a peek. The only place, I can see anything would have came from, is possibly a little overflow looking tube on the drivers side of the oil pan.
My question is this, Are any of you fine folks familiar with this tube, where does is come from, and why would it leak anything.
I did try to search for similar posts, with a similar problem, I was unsuccessful though.
Thank you all so much for taking the time read my post. Any input at all would be greatly appreciated.
T.
Old Feb 14, 2007 | 04:13 PM
Steina's Avatar
Steina
CO River Rat
The only thing I can think of is your heater core is leaking, and coolant is coming out the condensate drain for the A/C evaporator coil. Most drains are on the passenger side tho, so this may not be your problem.
Steve
Old Feb 14, 2007 | 06:05 PM
MisterCMK's Avatar
MisterCMK
That overflow tube you see is part of the transmission IIRC.
Check your heater core like Steina suggested and also check the hoses, radiator and freeze plugs.
My radiator leaks at the end tanks until the truck warms up but I will be replacing it under the radiator's warranty. Something to check though.
guitar_199
1997 - 2003 F150
Oct 18, 2010 07:34 PM
71dusterdan
27
Jan 13, 2009 05:31 PM
wmjoe1953
197
May 9, 2008 08:26 PM
ctubutis
Feb 19, 2008 07:46 PM
dogdude2003
Jan 11, 2005 01:34 AM
