1992 Ford explorer / rear end
Old Feb 14, 2007 | 01:22 PM
Don2's Avatar
Don2
I wanted to look into puttting a limited slip rear end in my explorer, what could i expect to get into? Thanks
Old Mar 4, 2007 | 08:24 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Bumped…let’s see if we can get you an answer here.
Old Mar 4, 2007 | 01:01 PM
JerrySimm's Avatar
JerrySimm
Easiest way would be to pull and change an entire axle from a junked one. However, if yours if 4x4 you'll have to do the front end as well. Also, after the change, you'll need to change your speedometer gear, or the speedometer will read faster than you're going. The limited slip was 3.73:1 and the open was 3.55:1.
Old Mar 4, 2007 | 03:50 PM
mrshorty's Avatar
mrshorty
What kind of LS were you looking for? I have Ford's Trac-Lock LS in both my Explore and my BII. Rebuilt both of them, and, overall, I'd say I've been dissappointed. If I were to start from scratch with an open carrier, I would prefer to put a lunchbox locker in there.
If you do decide to go JerrySimm's route, expect to have to rebuild the used Trac-lock. The clutches in those don't last forever. Also plan to spend the money to replace those clutches every 50K miles if you want to know LS is an LS.
There are several better LS options out there, but they require replacing the carrier (which means you need to pay to set up the gears if you don't know how to do it yourself). This can be a perfect opportunity to regear, if you're considering that, too. I think both Auburn and Detroit offer gear driven LS's that don't have any clutches to wear out.
Old Mar 4, 2007 | 09:59 PM
ebexp94's Avatar
ebexp94
Does anyone know which Explorers come with limited slip rear axles? I have a 94 Eddie Bauer 4x4 and a 91 Eddie Bauer 4x4 for parts, and was wondering if those are limited slip.
Old Mar 4, 2007 | 11:12 PM
mrshorty's Avatar
mrshorty
LS's came in many trim packages in every year. Best way to know is the check the axle code on the sticker on the door jamb (if you can say for sure that axles haven't been swapped since it left the showroom). I think all of the LS codes start with D, but I'm sure there's a full table of axles codes somewhere on the internet. And/or you can check the identification tag on the rear diff. The start of the 2nd line indicates gear ratio. LS's would have an L where the decimal would be (3L73 for example).
Old Mar 5, 2007 | 12:02 AM
cwix's Avatar
cwix
On the cover of the differential, there should be a little metal tag bolted there, on that tag are some numbers, the bottom row of numbers it says the gear ratio.. I.E. "3 55" means you have a gear ratio of 3.55 if it says "3L55" you have a limited slip 3.55
Same goes for other sizes.. I.E. 4.10
ETOWN55
35
Jan 24, 2015 07:14 AM
dferrell5
30
Jan 25, 2014 01:26 PM
n242
Sep 27, 2010 11:23 PM
61 uni
Feb 7, 2009 08:06 PM
