lower ball joint install trouble
Old Feb 13, 2007 | 06:06 PM
Tater17's Avatar
Tater17
I am putting new ball joints on my 2000 F-250 4x4 Powerstroke. I have reached the point where i need to torque the lower ball joint. I cant tighten it up because the middle keeps spinning. It has a slot in the moog ball joint that i am using but it is too big for a flathead screwdriver. Any help would be greatly appreciated. Thanks Again. The info I have got off of this forumin the past has been a tremedous help.
Old Feb 13, 2007 | 06:12 PM
sean23johnson's Avatar
sean23johnson
place a jack under the knuckle and jack it up. this will apply pressure to the balljoint and stop it from spinning. good luck!!!
Old Feb 13, 2007 | 06:26 PM
Tater17's Avatar
Tater17
I did jack up the bottom of the ball joint but it kept spinning when i would turn it with my wrench. I only lifted it off the jackstand about an inch. do you think that wasn't enough or is there another trick. Thanks again
Old Feb 13, 2007 | 06:30 PM
sean23johnson
yes, you jacked it up enough. have you tightened up the top balljoint all the way?? if not, try that. also, you might want to pull the knuckle off and examine the lower balljoint threads to make sure they look good. try to hand screw the nut on the lower balljoint.
Old Feb 13, 2007 | 06:31 PM
johnsps250's Avatar
johnsps250
If putting pressure with the jack doesn't work, I have cut and ground an old screwdriver to fit the slot to get them to tighten up. If I remember correctly, Moog lower ball joint nut is a lock nut so it goes on hard.
Old Feb 13, 2007 | 06:38 PM
Tater17's Avatar
Tater17
Thanks for all of the help. I did tighten the upper. the lower is fine it has a locknut. That is what is keeping it from spinning freely. I ll try grinding up a screwdriver tomorrow thanks again for all of the help.
Old Feb 13, 2007 | 06:40 PM
sean23johnson
bummer. i hate leaving projects unfinished. good luck
Old Feb 13, 2007 | 06:53 PM
shenders99's Avatar
shenders99
I used a c clamp on the ball joint and then it hit the knuckle, only way I could get it tight..
Old Feb 13, 2007 | 07:23 PM
mech2161's Avatar
mech2161
The last set I did by tightening the upper then useing an air impact with a universal to get the angle on the lower.
Old Feb 13, 2007 | 09:11 PM
Tater17's Avatar
Tater17
Thanks so much everyone who posted. These are great tips that I will try tomorrow. I'll post how it goes. Thanks again!!!!!
Old Feb 13, 2007 | 09:50 PM
Orezona's Avatar
Orezona
I just sent you a PM.
Old Feb 14, 2007 | 06:46 PM
Tater17's Avatar
Tater17
I just got them finished up. went pretty easy with the wonderful tip from Orezona. Thanks again to all that posted.
Old Feb 14, 2007 | 06:49 PM
Orezona's Avatar
Orezona
Very cool. Feels pretty good to get that job done doesn't it. It saved me a little over $500 dollars in labor alone.
Old Feb 14, 2007 | 06:54 PM
John311t's Avatar
John311t
I get to do mine again(oh fun!) for the second time in less than a year!
Old Feb 14, 2007 | 06:57 PM
Orezona's Avatar
Orezona
What happened?
