Sponsored by: Auxito
engine service due
Old Feb 13, 2007 | 02:52 PM
peter381's Avatar
peter381
engine service due
does anyone know how to turn off the engine service light on a 2000 150 Harley Davidson, have been to the local british garage engine runs like a dream now but they dont know how to turn the light off, HELP
Old Feb 13, 2007 | 03:31 PM
KingRanchMan02's Avatar
KingRanchMan02
Either with a code reader or disconnect the battery negative cable for 10 minutes. The code reader path will not effect the truck. The battery path will cause the truck to re-learn the fuel tables, etc. and it may run a little rough until the ECM re-learns.
Old Feb 14, 2007 | 01:10 AM
LxMan1's Avatar
LxMan1
Welcome to the Forum, Peter
Old Feb 14, 2007 | 07:24 AM
projectSHO89's Avatar
projectSHO89
If you don't want to have to reprogram your radio, just locate and pull the sincle fuse listed for PCM Keep-Alive Memory (KAM). Leave the fuse out for 10-15 minutes with the ignition OFF, then reinstall. Observe the drivability notice in your owners manual regarding PCM resets.
Steve
Old Feb 14, 2007 | 01:42 PM
peter381's Avatar
peter381
many thanks for the advice, will try when the rain stops and will inform of outcome
again THANKYOU
failure is not falling down
failure is not getting back up when you do
Old Feb 14, 2007 | 02:31 PM
thehawk789's Avatar
thehawk789
Disconnect the battery, but I'm worried your problem may still exist. If the shop couldnt clear it either they only have a generic code reader or they dont know what they are doing. Some DTCs take up to 3 consecutive test passes to clear and the MIL goes away. But the tricky part is that in order for the test to run certain criteria must be met.... and you may not be meeting that criteria, its complicated. Just try doing the battery for now.
Old Feb 16, 2007 | 02:54 AM
peter381's Avatar
peter381
thanks - SORTED
allways listen to advice before you decide wether its good or bad
NO BAD ADVICE ON THIS SITE!
FAILURE IS NOT FALLING DOWN
FAILURE IS NOT GETTING BACK UP WHEN YOU DO
