A question
Old Feb 13, 2007 | 02:15 PM
DJdemon6696's Avatar
DJdemon6696
Question A question
on the milage meter on my truck its now at 533664(2) < white one
but i bought the truck 2nd hand ... and its kind of a low mileage i tink.. so how do i know if it hasnt gone to 99999(9) and started at 00000(0) again ? or it isnt posibel ?
1990 F250
Old Feb 13, 2007 | 03:15 PM
Heavenword1's Avatar
Heavenword1
If you run a CarFax or similar report on the VIN, you can often tell if the vehicle mileage is accurate. The current mileage by date is usually on these reports for registrations and state inspections. Depending on your area, the information may be more robust than others.
Old Feb 13, 2007 | 03:26 PM
alz's Avatar
alz
So 533,664 miles seem kind of low for a secondhand 1990 truck? Did I miss something? Do you have an extra number in there?
Old Feb 13, 2007 | 05:57 PM
jroehl's Avatar
jroehl
There's no way to know for sure whether the odo has rolled over or not, but there are some clues. The most common one to look at is the brake pedal. If the bottom right corner is just slightly worn, then it's likely 53k. If it's worn smooth, think 153k, and if there's metal showing, you're probably pushing the 253k mark. Wear and tear in the driver's area are the best clues you'll get. Even the '92+ trucks rolled over at 400k, with the 6-digit (no tenths) odos (you can see on the self-check at startup that there is no line in the upper left of the first digit--a digital '4' would be the first numeral to need it).
Jason
Old Feb 13, 2007 | 06:28 PM
quicklook2's Avatar
quicklook2
the brake pad may have been replaced so that is not always a good indication of anything.
where did you get the first 5 from? the odo in that year does not have one.
Old Feb 13, 2007 | 07:05 PM
DJdemon6696
sorry!! i ment 53334 (8) its kind of low.. for an 2nd hand truck isnt it?
but if Jason is right... then i dont know for shure. because on the brake peddal i can see a bit of metal on the right low corner..
Old Feb 14, 2007 | 12:44 PM
lostin90s's Avatar
lostin90s
It will/can role over my 91 bronco did ""twice"" Course to took 2 motors . newer go to digital at just keep on ticking.
