Hub problem
Old Feb 13, 2007 | 10:47 AM
johnmvtv's Avatar
johnmvtv
Hub problem
H i guys,its my first post and i'm hoping that someone can help me out.Iown a 1190 f250,and in the last 3 years i have had to replace my hubs.No 4wheel.I am pretty aggressive when i 4 wheel but i cant figure out why they keep goin.Any ideas would be appreciated,thanks in advance
Old Feb 13, 2007 | 11:19 AM
kell104's Avatar
kell104
What hubs are you using? What modifications have you done to your truck. If you have huge tires that is probably your problem. Stock type hubs are not really designed for heavy duty wheeling with big tires. Try upgrading to the most heavy duty hubs you can find. Warn, Milemarker, Superwinch all make good hubs.
Old Feb 14, 2007 | 10:38 AM
d79f150's Avatar
d79f150
IMO stay away from superwinch unless you get their absolute premiums they use cast gears that shatter (I've been thru two sets) Warns uses a better material for their gear setups.
Old Feb 15, 2007 | 06:01 AM
johnmvtv's Avatar
johnmvtv
well unfortunately i just had new stock hubs put on and ihave to go pick the truck up today,but this is good info mechanics (ones that i know)dont know much about that stuff),i will kill these and then get some warn hubs theres a dealer right down the street thanks guys!
