Sponsored by: Real Truck
Transfer case motor
Old Feb 12, 2007 | 11:05 PM
dbl.throat_patch's Avatar
dbl.throat_patch
Transfer case motor
I need a link to a place where I can order one of these. This is the motor on the transfer case that engages the T/C. The problem I'm having is when I switch to 4h nothing happens, no 4x4 light or nothing. I have a 99 f250 superduty. Thanks in advanced for any help.
Old Feb 12, 2007 | 11:35 PM
shockwave6's Avatar
shockwave6
You can usually find them on eBay for a decent price. Be sure to check your switch/fuses/shift motor connector. You can also turn the switch and see if you are getting voltage at the shift motor to further isolate that it needs to be replaced before spending the dough
Old Feb 14, 2007 | 04:37 PM
kneexxtj's Avatar
kneexxtj
? Where is the shift motor on an 05 F-150?
I know this has to be a dumb question, but I have no idea where it is. I looked all around the transfer case and I'm not seeing it. There are no pictures in my Haynes rebuild manual either. I have the switch in my truck and it worked a few times before so I'm sure I have one somewhere. I need to replace it, but if I can't find it, that will be a difficult task. Any help would be great.
