Starter Grinding after Start
Old Feb 12, 2007 | 06:57 PM
rpatrick's Avatar
rpatrick
About 1 in 5 times when I start my 93 5.0l, the started makes a grinding noise just after the engine starts.
It is the same sound the starter makes when you try to start an engine that is already running.
I turn the key, the starter always engaes fully, the engine turns over, it starts and then it makes the grinding sound for just a split second after the engin stars. Does not happen every time but maybe 3-4 times a week.
Any idea what could be causing this?
Old Feb 12, 2007 | 07:02 PM
thelast50ho's Avatar
thelast50ho
the spring that pushes the starter gear could be broke or weak. Or in might be stickin. Id pull the starter off and check it out
Old Feb 12, 2007 | 08:19 PM
Redcat Diesel's Avatar
Redcat Diesel
I've got a couple other things to check for too.Before you pull the starter see if the bolts are tight.I've seen them back out and the starter drive hangs up on the ring gear.Also worn ring gear teeth or the sprag in the starter drive is breaking apart.Hope this helps.
Old Feb 13, 2007 | 09:43 AM
akaGWall's Avatar
akaGWall
I had the same problem on my '93. The solenoid (on top of the starter) was sticking. This part is available by itself, but I decided to replace the whole starter.
Old Feb 13, 2007 | 10:18 AM
dave2's Avatar
dave2
Much less headache and more piece of mind. Rock Auto has Bosch starters real
reasonable.
Good Luck,
Dave
Good Luck
Old Feb 13, 2007 | 11:22 AM
kell104's Avatar
kell104
Probably loose bolts or sticking drive. Pull the starter and bench test to see if the drive moves in and out freely.
Old Feb 13, 2007 | 11:53 AM
jprater's Avatar
jprater
i had the same problem and i replaced the starter twice then also the solenoid just couldnt get it to stop turns out it was my key switch staying on to far but you couldnt tell it look fine maybe this will help..
Old Feb 13, 2007 | 07:15 PM
rpatrick's Avatar
rpatrick
Thanks for the info.
After the latest snow clears, I'll check the bolts to see if the starter is firmly seated. It was replaced once long ago - maybe it worked lose.
If that is not the culprit, I'll pull it and take a look-see.
Rob
