Banging in front end
Old Feb 12, 2007 | 12:12 AM
dieselbogging's Avatar
dieselbogging
Question Banging in front end
This has been happening for a while now and i just noticed it the other day while going through a rough road in the city. It almost sounds like the ball joints on both sides are buggered but i checked them and they seem to be alright. Everytime i go over a sudden small bump i here a bang. Not all that loud but noticeable.
My tires are only 3 months old and are both wearing to the inside which indicates that the front end is out of alignment. But before i go in for an alignment i want to make sure nothing is wrong.
I have also noticed when i lift one tire off of the ground when i attempt to turn the tire, the tie rod joint where the steering arm from the power steering attaches to the tie rod will allow the tie rods to move back and forth yet none of the tie rod ends have any play up and down or side to side. It moves on the joint without any play that would point to a worn out tie rod end. Its hard to explain but i think that could be the problem. Also sometimes the truck wants to turn to the right wile going down the highway and someties it wont.
Any idea to what would cause this?
Old Feb 12, 2007 | 04:10 AM
PLC7.3's Avatar
PLC7.3
Get a front end check from a local tire store for starters. Check the spring end bushings see if they are worn out.....the spring can contact the frame under your feet. I replaced spring bushings with Energy Suspension parts last summer.
Tough to diagnose over the net.......
Old Feb 12, 2007 | 04:40 AM
mistakenID's Avatar
mistakenID
Check the shocks also, worn bushings on shocks can make a lot of noise on small bumps.
Old Feb 12, 2007 | 05:38 AM
fonefiddy's Avatar
fonefiddy
I'd allmost bet that the rubber bushings in the IFS are worn out.
Old Feb 12, 2007 | 08:42 AM
roamer37's Avatar
roamer37
Are you saying there is play at the steering gear to drag link or the pitman arem is moving back and forth..? the drag link that goes across the truck has a joing that wears out at the pitman arm..
Check the bushing on the radius arms.. to the frame under your feet where the attach to the frame.. these wear out.. a lot..will make a lot of noise not real hard to change.. aslo the brackets rust out and need to be replaced pretty common
Old Feb 12, 2007 | 10:20 AM
PLC7.3's Avatar
PLC7.3
He has the 4x4.... no radius arms.
Old Feb 12, 2007 | 01:32 PM
davelong667's Avatar
davelong667
I had clunking noises on my 88 250 when i hit the washboards on the dirt road by my house. I replaced the shocks front and rear and the noises went away completly.
Old Feb 14, 2007 | 07:06 PM
dieselbogging
So those rubber bushings are pretty common to puke out hey!!! How hard are they to change and how much am i looking at to replace them?
Old Feb 16, 2007 | 02:51 AM
PLC7.3's Avatar
PLC7.3
After you find out what the problem really is........if your interested in Energy Suspension products...... where I got mine......
call:
Auto Parts Center
(204) 783 7400
1102 Notre Dame Avenue, Winnipeg, MB R3E 0N8
Old Feb 16, 2007 | 03:07 AM
95-F250's Avatar
95-F250
My old 84 had a clunk when I hit bumps, it was the leaf spring bushings.
I got the poly ones from Energy, you can have the old ones pressed out or
do it the hard way like I did, I drilled holes in the rubber with a 1/2" bit until I had room to get in a sawzall blade and sawed through the steel sleeve part then hammered them out.
Old Feb 16, 2007 | 07:53 PM
matts156's Avatar
matts156
When I replaced the bushings on my IFS, I didn't have to cut the sleeves to get them out. They were so worn that one was halfway through the sleeve and the other had cut completely through the sleeve and had worn a 1-inch wide X 1/8-inch deep groove in the axle arm. I had to weld in some filling and grind it down to make it round again.
Old Feb 16, 2007 | 10:12 PM
dieselbogging
How much are those bushing here in manitoba???
Old Feb 17, 2007 | 01:44 AM
matts156's Avatar
matts156
I don't know about your area, but I bought regular rubber replacement bushings for about $10 each. When my wife is back to work, I'll start thinking about replacing all bushings throughout with the nicer polyurethane variety.
Old Feb 17, 2007 | 03:50 AM
fonefiddy's Avatar
fonefiddy
You can buy a complete kit of poly bushings for around $100
http://www.energysuspension.com/pages/fdt1.html
Old Feb 17, 2007 | 09:24 PM
dieselbogging
Alright thanks.... One more question. Can those bushing through the front end out of alignment?
