condensors
Old Feb 11, 2007 | 11:57 PM
customfoam's Avatar
customfoam
condensors
Would any one know if a 94 95 condensor fit on a 93, the 93 if r12 and the other is for r134? what changes besides condensor and orifice tube?
Old Feb 27, 2007 | 12:52 AM
bustech81's Avatar
bustech81
the fittings should be the same.(on the condenser)if you are adding an r134 condenser to your r12 system,way to go! with the higher operating pressures of the blended refridgerant, the newer condenser is a higher b.t.u. and will lower your liquid charge temp for better preformance. be sure to flush it out though because the oil changes between the two refrigerants. a drier is always a good investment.
Old Feb 27, 2007 | 06:13 PM
customfoam's Avatar
customfoam
r134 condensor
Yes If the fittings are the same I'll definitely change it as I notice they are more efficient in the temp difference, and thanks for the info.
