1978 - 1996 Big Bronco
rear window stuck down
Old Feb 11, 2007 | 06:17 PM
nelly781's Avatar
nelly781
ok, i know this has happened to someone before, my window is stuck in the down position and the window motor isnt working, i disconnected the key thing along time ago. but i cut the wires that run through behind the driver's tail light and hooked a 12v source to it there, so its gotta be the motor. i cant get to the motor with the window down. what do i do? i dont wanna break the glass!!
Thanks,
David
Old Feb 11, 2007 | 07:04 PM
b4hntn's Avatar
b4hntn
Push on the tailgate above the keyhole to be sure the safety switch knows the tailgate is closed while you attempt to raise the glass.
Old Feb 12, 2007 | 11:40 AM
460srule's Avatar
460srule
When the gate is open,you can close the lock to fool the safety switch.What your fingers.Also be careful of the window as it comes out.Take the panel off the gate and look for loose or broken wires but I think the safety switch is probably not getting closed.Mine will do that at times and the easy solution is to move the Bronco to level ground.
Old Feb 12, 2007 | 04:41 PM
nelly781's Avatar
nelly781
when i re-wired it, i bypassed the safety switch, i know because ive had my tailgate down before and make the window go up and down. sooo....any other ideas???
