1987 E-150 No Start
Old Feb 11, 2007 | 05:59 PM
SteveOntario's Avatar
SteveOntario
1987 E-150 No Start
Hello,
I am new to the forum. I have a fairly well cared for Econoline beater with about 130,000 km. It hasn't been able to start since I parked it for the winter. It seams to be that I am not getting power to the computer because I can't hear the fuel pump turn on with the key and I don't get any spark but it turns over very well. Everything else electrical works... The fuel tank is about half full and I have a 6 year old federal-mogul fuel pump. It is very noisey normally.
I have a Haynes manual and don't find the electrical diagrams for it very helpful. Does anybody know where the main power wire on the starter relay goes in this van? I want to test for voltage at its far end from the relay without cutting into it. Is there a common part on these things that gives up? I loosened off the wires on the starter relay and moved them around a bit to clean them but that did not help. Also, I can feel the starter relay click in my hand when I turn the key.
Thanks, Steve
Old Feb 11, 2007 | 06:02 PM
SteveOntario
oh yeah, this van has an inline 6 with a C6 auto. Regular wheelbase, 1 tank, 2 seats.
Old Feb 12, 2007 | 10:59 PM
Dannym's Avatar
Dannym
There is an intertial shutoff which cuts off power to the fuel pumps if jarred, or sometimes if it just decides to not work anymore.
Not sure where it is on a C6.
Old Feb 13, 2007 | 08:35 AM
subford's Avatar
subford
First off the computer has nothing to do with you not getting any spark.
You need to fix the no spark problem first and then worry about the fuel.
However the fuel pump should come on for one second and then stop running when you turn your key to the ON (RUN) position.
If you do not get it to run for one second then we have a power problem in the circuit from the starter solenoid, fuse link, EEC Power relay area.
If it does run for one second then you have a problem in the TFI Module, Distributor Pick-up or Ignition Coil area.
Here is a diagram that should be close to what you have.
http://i54.photobucket.com/albums/g9...1tankE1505.gif
Old Feb 17, 2007 | 12:38 PM
SteveOntario
Hi guys,
I checked the intertia switch and then went through the wiring diagram. It was much better than what Haynes provides. I changed my fuel pump so I now have fuel to the engine. I'm half way to running!
I also took my distributor cap off and probably did some damage to it... I sanded down the rotor, is it supposed to be a full copper bar or just the tips? I also sanded off one of the cap contacts before I realized it was supposed to be furry. Will I need a new cap and rotor now?
My coil is getting battery voltage and my aftermarket tach twitches when I'm cranking over the engine so I think I'm getting a signal to the distributor.
Any suggestions? I am going to look over the manual a bit more to see if I can't figure out what is going wrong. Every once in a while the engine gets a touch of spark because it speeds up a bit while turning over.
Cheers, Steve
Old Feb 17, 2007 | 02:00 PM
SteveOntario
I've got it worked out a bit more. I now have spark and can run the van on a light spray of ether. I think I'm only getting my low pressure pump to come on. I don't get a high pressure spray when I hold the fuel rail valve in when I turn the van over.
It's strange that so many issues would come up at once.
dakota-boy
Electrical Systems/Wiring
Mar 14, 2016 09:29 AM
cyris426
Nov 22, 2012 09:10 AM
flyn.brian
Jan 17, 2012 10:36 PM
02X72
Nov 5, 2010 04:54 AM
Traderjoe28
General Automotive Discussion
Jul 21, 2006 03:33 PM
