1978 - 1996 Big Bronco
Please Help with my Bronco's.... Engine Stalling
Old Nov 23, 2002 | 07:46 PM
JBronco's Avatar
JBronco
Old Nov 27, 2002 | 12:08 PM
Slacker83
Guest
Posts: n/a
I bought a 87 bronco for a beater in the winter to store my mustang. It has the 351W with a holley 4 barrel that came from the factory. It has been stalling whenever going away from a stoplight.
It doesn't do it all the time and doesn't seem to matter if the truck is hot or cold. I have replaced the fuel filter in the carb, fuel pump on the block, plugs were good, cap and rotor look great, there are some vacuum lines that are pluged because it used to have ac but I'm not sure if some should still be plugged in.
I set the idle to 1500 while in park and 1000 while in drive.
The thing really drinks the gas I think I am getting 6 to 7 miles a gallon.
Thanks Steve
Old Nov 27, 2002 | 04:40 PM
tomridge's Avatar
tomridge
Slack,
I had a similar problem on my newly aquired 86, also with the carbed 351HO. I ichanged carbs with a factory rebuilt one and it solved most of my problems. runs much better, drinks the gas though. I am getting about 11mpg. I know I have troubles in the spark department so that will be next.
Tom
