engine swap
Old Feb 11, 2007 | 02:03 PM
youngfordguy's Avatar
youngfordguy
engine swap
i have a 81 f150 that i have been working on for the past little while. i just picked up a 302 for nothing and was wondering if it will bolt to the 4 spd tranny that the stock inline six bolted to. any help would be great and if it dosnt what tranny dose thanks.
Old Feb 11, 2007 | 02:26 PM
mikeyswood's Avatar
mikeyswood
You will need some other mods, but the 302 is the same pattern as the 300.
Mike
Old Feb 11, 2007 | 02:31 PM
Tdvjensen's Avatar
Tdvjensen
The other mods that mike was talking about would be frame mounts for the motor, modifying the exhaust for the 302, different flywheel and clutch assembly, rad and rad hoses, as well as accessory drives. other than that you should be good to go. Have fun and good luck.
Old Feb 12, 2007 | 09:07 AM
youngfordguy
thanks that was the bigest thing was if the bell housing from the tranny will bolt everything else i have
