P1670
Old Feb 10, 2007 | 10:17 PM
sneak's Avatar
sneak
P1670
Read codes today on my 02 and one of them was P1670. What does it mean to have a "P1670 Electronic Feedback Signal Not Detected" code go off???
Old Feb 11, 2007 | 01:19 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Are you having any problems? What symptoms led you to pull codes and what did you use to pull it?
Old Feb 11, 2007 | 01:32 AM
AustinS's Avatar
AustinS
That's an Injector Driver Module code. It means the IDM is not communicating W/ the PCM. I'm assuming your trauck isn't running, or running real bad.
We would like to help, but we need more info.
Austin
Old Feb 11, 2007 | 08:31 AM
sneak's Avatar
sneak
I've been having some problems starting the truck in sub zero weather and if I park it when the truck is hot and it goes to high idle, after a while it starts to run poorly. I believe, in that case that it may have just been because the system voltage was too low.
Old Feb 11, 2007 | 08:42 AM
Uzumati's Avatar
Uzumati
The IDM provides the EF output signal to the PCM to confirm that proper timing/duration of fuel delivery command signal (FDCS) was received. Additionally, the EF signal is used to send diagnostics of the IDM and injectors (electrical) to the PCM.
Possible causes:
Open fuse
DM relay
Open or shorted IDM enable circuit
Open/short in EF circuit
Open/short in FDCS circuit
IDM powering circuits
PCM
PM me your email address and I'll send you the pinpoints.
fordguy2236
38
Oct 14, 2023 01:04 AM
garndog
Sep 30, 2017 02:35 PM
Ford_7.3
Nov 27, 2014 07:51 PM
blackdakotadave
29
Jan 17, 2012 07:16 PM
johnt471
Jan 5, 2010 09:00 PM
