272 Coil Wire Placement
Old Feb 10, 2007 | 05:48 PM
WALFORD'S 56's Avatar
WALFORD'S 56
Question 272 Coil Wire Placement
hI GUYS!!!My 56 has a 272 y-block and it runs good,even though it has not been on a trip yet.The battery light is on when I run it,and it must be discharging.Where do all the wires going to the coil go to?There are 3 wires on mine,and if they are on wrong,will it discharge?thanks
Old Feb 11, 2007 | 05:37 PM
312's Avatar
312
the - one goes to the dist,the other 2 go to plus side.
Old Feb 11, 2007 | 05:59 PM
WALFORD'S 56
Thanks 312!!!I will check it out in the morning!!
Old Feb 11, 2007 | 07:11 PM
arctic y block's Avatar
arctic y block
After checking the coil as that may be where ya get juice to the field post on the generator. you must have juice to the field wire when the key is on to excite the generator. Also after all the above try and polarize the generator.
Old Feb 11, 2007 | 07:32 PM
WALFORD'S 56
Thanks ARCTIC YBLOCK!!!If it wasn't for you my 56 F600 would not sound and run as good!!!I wonder if the generator is charging or not.I will see in a.m.
Old Feb 11, 2007 | 08:51 PM
arctic y block
It won't hurt ta pull a neg cable of the batt. While she is at a fast indel. If it dies than it ain't working,
