1978 - 1996 Big Bronco
78 bronco 4wd doesn'twork
Old Dec 1, 2002 | 09:35 AM
shelby cobra's Avatar
shelby cobra
I have a bronco that has manual 4wd. Last night in the driving snow storm it wouldn't shift into 4wd. Why? The transfer case is working and the hubs are also locked in. Any ideas?
Old Dec 1, 2002 | 05:56 PM
Churchboy2121's Avatar
Churchboy2121
Is the front drive shaft turning. If it is turnning it sounds like the lockouts are not fully locking in,
'79 Bronco XLT
If it wasan't for imports my tools would rust!
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=10374&.jpg
Old Dec 1, 2002 | 10:54 PM
BOJOFASO's Avatar
BOJOFASO
I HAD A 75 F-250 THAT DID THE SAME THING IT TURNED OUT THAT THE LOCKING MECHANISM ON THE PASS SIDE GOT A LITTLE RUSTY AND THE HUB WASNT REALLY LOCKED IN. PLACE THE TRANSFER CASE IN NEUTRAL AND CLIMB UNDER THE TRUCK WITH THE FRONT HUBS LOCKED AND SEE IF YOU CAN TURN THE DRIVESHAFT. IF YOU ARE ABLE TO TURN IT ONE OR BOTH OF YOUR HUBS ARE NOT LOCKING IN.
GOOD LUCK AND I HOPE THIS HELPS.
Old Dec 2, 2002 | 04:28 PM
shelby cobra
Thanks for the info. I will surely try this and let you know what happens!:-X12
Old Dec 2, 2002 | 04:30 PM
shelby cobra
Thanks!
Will post a reply after I get the problem fixed. :-)
Old Dec 2, 2002 | 05:34 PM
greystreak92's Avatar
greystreak92
