Positive Ground?
Old Feb 10, 2007 | 04:36 PM
lj98's Avatar
lj98
Positive Ground?
With the discussion of 6 to 12volt I was wondering about changing to neg. ground.
Old Feb 10, 2007 | 06:37 PM
mtflat's Avatar
mtflat
That's the easy part. Either 6 or 12V you just change your battery cables, swap the wires on the coil, run the wire thru the ammeter backwards and polarize your generator.
Old Mar 10, 2008 | 07:01 PM
newblder's Avatar
newblder
When you change from a 6v to 12v, do you have to change a pos. ground to a neg. ground?
Old Mar 10, 2008 | 08:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Pretty much have to, unless you use a generator, and can find a 12v pos. ground regulator. None of the 12v alternators come pos. ground. If you're going to all the trouble to convert to 12v, there is no good reason to stay pos. ground.
