1978 - 1996 Big Bronco
Brakes clunking.
Old Dec 2, 2002 | 09:42 AM
90EBBronco's Avatar
90EBBronco
Brakes clunking.
Over the past couple of weeks I have noticed my brakes clunking while depressing the brake pedal. Since then I have replaced all four sides to no avail. It feels like the clunk is right under the driver's seat and the only thing down there is the Hydraulic Control Unit for the ABS system. Are the pistons contained within the HCU big enough or have enough pressure behind them to clunk when I quickly depress the pedal? I thought it might be the hardware on my lift kit that might be loose in some spots but I took and impact wrench to them and I know they are tight. It also doesn't matter how fast I am going. If I hit that pedal quickly it clunks. What about the power booster or the master cylinder? Could they be the culprates? Any ideas would be greatly appreciated as I will be getting some Xmas money in the coming weeks to spend on my beloved truck. Thanks in advance!
KJ
Old Dec 2, 2002 | 10:51 AM
fcarruth's Avatar
fcarruth
Brakes clunking.
Mine did the same thing mid-Summer but it was the tie rod assy. I replaced it all and mine has not made the clunking noise since.
I am sure you will get other suggestions but hope this helps.
Old Dec 2, 2002 | 11:38 PM
klmken's Avatar
klmken
Trailering
Brakes clunking.
Check your radius arms and bushings......mine are loose and it does it everytime I step on the brakes....right under the drive seat as well.
Ken
Old Dec 2, 2002 | 11:44 PM
Devil's Avatar
Devil
Brakes clunking.
