'94 explorer ABS question
Old Feb 10, 2007 | 01:28 PM
dbemowsk's Avatar
dbemowsk
I am wondering how to get the error codes from the ABS system on a 94 ford explorer. My ABS light is on constant and I want to find out what the system is saying the problem is. Is there a way to jump a connector wire to ground and watch the ABS light flashor something similarily easy to do?
Old Feb 11, 2007 | 03:32 PM
elcaliente's Avatar
elcaliente
1994, your truck is 13 years old, more than likely your front sensors are damaged in some way. the best way to find out is to pull your front tires and visually check the wiring harness on each side of the vehicle . i have a 1993 4x4 2dr and have had to replace both my sensors usually its the harness thats damaged in some way. cost me $110 both sides from napa auto. good luck.
