cold start transmission problem
Old Feb 10, 2007 | 12:34 PM
03edgedrvr's Avatar
03edgedrvr
Question cold start transmission problem
Hello, I just bought a 03 ranger edge 4x2 automatic with 36,000 miles a couple months ago. I have to let it sit and warm up for about 30 seconds before shifting or else it will have a shutter when engaging. After its went into gear or warmed up I don't seem to have a problem. Every other vehicle I've driven has been able to start up, shift and get going without warming up. Is this common or does it sound like something could be wrong. No other problems.
Old Feb 12, 2007 | 07:11 AM
Randy Pederson's Avatar
Randy Pederson
This doesn't sound like a problem it's fairly normal up here to have to run 2-3min. before driving in cold weather I usually run it 5-10 min. because I hate a cold truck and Ive always thought you were supposed to warm it up before driving. If you don't you will cause unnecessary problems and engine wear. This is assuming that your weather is as cold as ours. (today it was -14)
Old Feb 12, 2007 | 07:59 AM
sfcwoodret's Avatar
sfcwoodret
At those kind of temperatures, you want to warm any vehicle up for several minutes anyway. Very cold temps. can be hard on engines and trannys when ran under those conditions. A check often on oil and fluid levels are a must.
