timing
Old Feb 10, 2007 | 09:49 AM
rmalottwtes30's Avatar
rmalottwtes30
timing
I have this cam in my truck. What degree do I need to set my timing at to get it perfect? I am running a Accel Dizzy and accel 8.8 wires. and a pete jackson gear to gear timing. So what else info do you need to know what to set the timing at? Thanks
<table border="0" cellpadding="0" cellspacing="0" height="1268" width="504"><tbody><tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%"> Brand:</td><td class="overview-c2" width="75%">Crane Cams</td></tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Product Line:</td><td class="overview-c2" width="75%">Crane PowerMax Cam and Lifter Kits</td></tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Cam Style:</td> <td class="overview-c2" width="75%">Hydraulic flat tappet</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Basic Operating RPM Range:</td> <td class="overview-c2" width="75%">2,000-5,000 RPM</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Intake Duration at 050 inch Lift:</td> <td class="overview-c2" width="75%">216</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Exhaust Duration at 050 inch Lift:</td> <td class="overview-c2" width="75%">228</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Duration at 050 inch Lift:</td> <td class="overview-c2" width="75%">216 int./228 exh.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Advertised Intake Duration:</td> <td class="overview-c2" width="75%">272</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Advertised Exhaust Duration:</td> <td class="overview-c2" width="75%">284</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Advertised Duration:</td> <td class="overview-c2" width="75%">272 int./284 exh.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Intake Valve Lift with Factory Rocker Arm Ratio:</td> <td class="overview-c2" width="75%">0.484 in.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Exhaust Valve Lift with Factory Rocker Arm Ratio:</td> <td class="overview-c2" width="75%">0.512 in.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Valve Lift with Factory Rocker Arm Ratio:</td> <td class="overview-c2" width="75%">0.484 int./0.512 exh. lift</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Lobe Separation (degrees):</td> <td class="overview-c2" width="75%">112</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Intake Valve Lash:</td> <td class="overview-c2" width="75%">0.000 in.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Exhaust Valve Lash:</td> <td class="overview-c2" width="75%">0.000 in.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Grind Number:</td> <td class="overview-c2" width="75%">H-272-2</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Computer Controlled Compatible:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Lifters Included:</td> <td class="overview-c2" width="75%">Yes</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Lifter Style:</td> <td class="overview-c2" width="75%">Hydraulic flat tappet</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Valve Springs Included:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Retainers Included:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Locks Included:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Valve Stem Seals Included:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Timing Chain and Gears Included:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Assembly Lubricant Included:</td> <td class="overview-c2" width="75%">Yes</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Pushrods Included:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Rocker Arms Included:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Gaskets Included:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">CARB EO Number:</td> <td class="overview-c2" width="75%">D-225-24</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">
</td></tr></tbody></table>
Old Feb 10, 2007 | 10:11 AM
baddad457's Avatar
baddad457
Cam timing? run it straightup. Ignition timing? start it at 12* BTDC and work with it from there.
Old Feb 10, 2007 | 11:01 AM
Beechkid's Avatar
Beechkid
That is a faily mild cam...start at the oem specs and go from there.
