Sponsored by: Innova
03 Expy..upgrading radio...
Old Feb 10, 2007 | 08:35 AM
IGoDwnTwn's Avatar
IGoDwnTwn
Greetings People,
Got a 03 Expy..XLT. Came with am/fm cassette/single CD player
Upgrading to..
Stock (Ford) am/fm stereo 6-CD changer.
Just a simple question.....where and/or how to I get the dashboard off. I wanna make this a simple pull...install..put together job. No other changes to be done.
Thanks All!!
IGO
Old Feb 10, 2007 | 09:02 PM
bucky440's Avatar
bucky440
Rmove radio first. Inside radio opening are two fasteners, remove them. The dash face then pull off (it's help on with clips) You don't need to pull the dsh fsce to change the radio to another Ford unit.
Old Feb 13, 2007 | 09:00 AM
IGoDwnTwn's Avatar
IGoDwnTwn
Okay ...let's start again.....HOW do you remove the radio. There are no holes...no handles. Do remove the center console and push it out? There's nothing there to PULL with.
IGO
Old Feb 13, 2007 | 02:41 PM
CobraXP's Avatar
CobraXP
I haven't worked on an Expy lately, but I believe you have to remove 2 bolts from the main cluster cover. They are located in the top section of the panel in front of the speedometer cluster. After those are removed, you can pull the entire face panel off. After that, you will see the mounting bolts on the bottom of the radio that hold it in place.
On Edit:
Check this link and go to page 2:
http://www.metraonline.com/_assets/m...NST99-5026.pdf
Old Feb 14, 2007 | 05:31 AM
IGoDwnTwn's Avatar
IGoDwnTwn
Now that makes sense....thanks Cobra.
IGo
Thuner
Oct 3, 2007 05:58 PM
jrmac22
Feb 19, 2007 10:50 PM
fordhonda
1997 - 2003 F150
Sep 20, 2006 10:24 PM
yoscott
Jul 3, 2005 10:51 PM
