Sponsored by: Real Truck
99' mis-fire
Old Feb 12, 2007 | 09:26 AM
redford's Avatar
redford
FTE Leadership Emeritus
Have you checked to see if you're catalytic converter is clogged?
Old Mar 26, 2007 | 09:30 PM
turbotuner's Avatar
turbotuner
I have had same problem more than once.one time it was mas air sensor,then spark plugs,then pourus hose to egr sensor,I even had a low rpm skip from a pcv valve. It is very unusual for a ford dealer unable to find the problem when they put it on their diagnostic machine.Maybe this dealers machine is broke and there not telling you.You might want to try another dealer. Waiting for a check engine light is not the answer I have had several problems with no check engine light
