Sponsored by: Auxito
'97 f150 5.4 rough acceleration
Old Oct 28, 2002 | 01:08 PM
lrk_nm_2002's Avatar
lrk_nm_2002
I have a 1997 F150 with the 5.4 Liter engine, 118000 miles, and recent development of a knocking sound at all engine speeds.
I changed the fuel and air filters, pulled and changed the spark plugs, checked cylinder compression with all cylinders indicating between 150 and 160 psig, checked all injector resistance, checked all injector circuits for proper signal, checked all coils (changed one dead coil), cleaned the fuel injectors using BG cleaner, installed new catalytic converters and duel exhaust due to a suspected restriction in one of the converters.
The results have been good except that the engine still hesitates and misses during cold throttle up. It is more severe during hard acceleration. It improves significantly after the engine has warmed up. The knocking sound has been eliminated.
Any ideas of other items I should check? Could it still be a fouled injector?
Old Oct 31, 2002 | 08:11 PM
geoaigel's Avatar
geoaigel
Replace your spark plug wires!
George
Old Oct 31, 2002 | 08:35 PM
kspilkinton's Avatar
kspilkinton
For an older motor, replacing wires would make sense. 5.4 doesn't have wires it uses a coil on plug configuration. Sorry George.
-Kerry
Old Dec 29, 2002 | 05:32 PM
als150's Avatar
als150
>speeds.
>eliminated.
>fouled injector?
You might check the coolant temp sensor and see if it is within tolerance. It may not be feeding back the correct temp to the PCM and taking longer then normal to come out of warm up.
Hope it helps.
Al
Old Dec 30, 2002 | 12:19 PM
99ford's Avatar
99ford
mdec950
Feb 7, 2015 08:58 PM
dhess67
2004 - 2008 F150
Jan 5, 2012 02:00 PM
damnford101
1997 - 2003 F150
Jul 14, 2010 03:04 PM
MikeFlorida
1997 - 2003 F150
Mar 2, 2008 08:07 PM
