95 4wd Rotors??
Old Feb 9, 2007 | 12:26 PM
428fourby's Avatar
428fourby
95 4wd Rotors??
Hi, I ran into a problem while installing new rotors! The stud holes are to big, and when I pound them in they are tight in the hub but not on the rotor, so when I grab the rotor I can move it back and forth a little. I measured the hole in the old rotor and its almost 1mm smaller and the studs fit tight.
I went back to the parts store and they are supposidly the right rotors, they called there tech line and the hole sizes are correct, yet when he tried a new stud off the shelf it was sloppy also!
At the parts store we also checked a rotor off of a 92 as it listed a different #.
The holes were smaller and the studs fit snug! The funny thing is the 92 and the 95 call for the same studs!(so why are the hole sizes diff in replacment rotors?)
The discs were thicker though so I couldn't use them.
Has anyone ran into this before? Thanks!
Old Feb 9, 2007 | 04:28 PM
wrenchturner's Avatar
wrenchturner
the truck is hub centric and holds the weight on the hubs. it is centered by the hubs. throw'm old and bolt everything on. good to go!
Old Feb 9, 2007 | 05:20 PM
428fourby's Avatar
428fourby
aren't the rotors going to rattle around if there not solid? And maybe wear into the studs.
Old Feb 11, 2007 | 03:00 PM
428fourby's Avatar
428fourby
Could I tack the rotor to the studs with a small weld, just to keep it solid?
Old Feb 11, 2007 | 03:51 PM
Tdvjensen's Avatar
Tdvjensen
First off, the rim is centered by the wheel studs, and is not hub centric. Secondly, DO NOT WELD ON YOUR HUB OR YOUR ROTORS. This could potentially cause problems with the rotor itself, and more importantly the wheel bearings from the heat from welding, and due to that both materials are cast the bead wont stick worth a **** and could cause them to crack. I would go to ford and see if they have the proper wheel studs to fix your sloppy stud problem. Also when you pound them in, also tighten them up with the lug nuts to make sure they are seated properly.
Old Feb 11, 2007 | 05:15 PM
lostin90s's Avatar
lostin90s
the rotor is tight in between rim and hub . Look at the goofy hub set up on 88-89 trucks where outer hub comes off. Those rotors "At least the one I had new" was held on with small clips on studs. I'd check other places and check studs to the splines my not be long enough. But you should be fine as 90% of car/trucks today you can remove hubs without messing with studs.Good luck
