Need an approximate dimension.
Old Feb 9, 2007 | 10:05 AM
delaney's Avatar
delaney
I have the cab off the frame on my 53 F100 so I cannot measure something I need. Approximately how much room is there between the top surface of the truck frame and the floor of the cab? If there is enough clearance I want to run the fuel line from an electric fuel pump on the top surface of the frame.
Thanks
Old Feb 9, 2007 | 10:42 AM
Jag Red 54's Avatar
Jag Red 54
The clearance on mine is about a finger width as I recall. But remember that the cab flexs on the rubber mounts. I would be afraid that the fuel line would get pinched during normal operation or even cut in an accident. My line is inside the frame where it is protected. Good luck, Jag
Old Feb 9, 2007 | 12:13 PM
brucewolff's Avatar
brucewolff
I agree, I won't put it on top the frame.
Old Feb 9, 2007 | 04:01 PM
4tl8ford's Avatar
4tl8ford
Got to say bad idea, fuel and brake lines max protection required.
Old Feb 9, 2007 | 05:21 PM
tacson's Avatar
tacson
Delaney,
Not to sound like a broken record but I agree with the previous post. The cab does flex still and have slight movement. It could pinch them lines quick. Here is the routing of my lines on the passenger side of my 55' which has a 302 EFI engine using a stock ranger pump. Thanks Donald
Old Mar 23, 2007 | 02:07 PM
harold morgan's Avatar
harold morgan
Is that also a Ranger Frame under your '55?
Old Mar 24, 2007 | 01:46 PM
tacson's Avatar
tacson
No, it is the stock F100 frame at that point. Thanks
