Reduced Voltage at All Lights
Old Feb 8, 2007 | 03:38 PM
slstreit's Avatar
slstreit
The dash lights, dome light and other lights on my 77 are not as bright as they once were.
In checking things out, I found that voltage at every light on the truck is about 1.2 volts lower than battery base voltage which is 12.39v.
Would this be a regulator issue? It looks to be the original. What is a recommended troubleshooting procedure?
Thank You
Old Feb 9, 2007 | 12:17 AM
SPL Tech's Avatar
SPL Tech
hmm.... thats an interesting one. I would start by finding the relays that the headlight circuit run through and test the voltage there.
Old Feb 9, 2007 | 12:40 AM
slstreit's Avatar
slstreit
Thanks!
Old Feb 9, 2007 | 10:53 AM
Franklin2's Avatar
Franklin2
Unless the wiring has been modified, 1977 did not have any relays for the headlights. Get the truck running, and take a voltmeter and check the battery voltage. It should be around 14.5 volts.
