timing
Old Feb 8, 2007 | 01:17 AM
wheily's Avatar
wheily
timing
i have a88 ford f150 5.0 auto w/od. recently i noticed when the truck is warmed up 190% it pings each time it shifts the timing is right at 10%b. what could be causing this ? ido have a muffler deleate in to a 3inch stack and the fuel pressure is at 35 psi dont no if thats were it should be . i have cleaned the iac and both cats, are new also at idle every once and awhile it will get real rough sounding (truck gets the shakes). thanks for the help
Old Feb 8, 2007 | 06:05 AM
subford's Avatar
subford
Did you pull out the SPOUT jumper when you set it at 10*BTDC?
Idling at 35 PSI is OK.
Lift the hood at night in the dark and see if you see sparks jumping.
Old Feb 8, 2007 | 05:40 PM
wheily's Avatar
wheily
what is the spout jumper i didnt see a vacum line so my brain went in to limp mode and i did it as it sits
Old Feb 8, 2007 | 06:09 PM
subford's Avatar
subford
You must pull the SPOUT jumper or the timing will be way off.
SPOUT - Spark Output Signal from EEC
88 Spout:
http://i54.photobucket.com/albums/g9...out88small.jpg
Old Feb 9, 2007 | 02:25 AM
wheily's Avatar
wheily
thanks for the help and link
