Sponsored by: Auxito
tech files?
Old Feb 7, 2007 | 11:01 PM
gcoe's Avatar
gcoe
tech files?
I keep finding references to tech files or tech tips but can't seem to find them. Would someone please give this newbe a bit of guidance?
Thanks
Old Feb 7, 2007 | 11:26 PM
3-RANGERS's Avatar
3-RANGERS
Smile
If you are searching for other articles relating to something. Click on the search button above and click on the advanced search area and decide where to look and use the keywords of your choice.
I hope that is what you are looking for. Joe
Old Feb 8, 2007 | 10:02 AM
KingRanchMan02's Avatar
KingRanchMan02
At the very top of the page, right under the word "Truck" in Ford Truck Enthusiasts, is the pull down menu for "Recalls/TSBs". TSB stands for Technical Service Bulletins. Enjoy!
Old Feb 8, 2007 | 10:16 AM
gcoe's Avatar
gcoe
Thanks to both of you.
I have a loose passenger side mirror which obviously needs to be tightened from inside the door. I've been trying to figure out how to get the panel off but haven't had any success.
This is a big site and seems to have a lot of information but my searchs on individual subjects bring back pages of postings most of which have little or nothing to do with what I'm looking for. I'm sure it's just a matter of learning my way around but it's taking time.
Old Feb 8, 2007 | 12:10 PM
LxMan1's Avatar
LxMan1
On my 01, you remove the bezel from the door handle and remove the screw under there. Then, you pop off the trim piece that goes up the rear side of the door next to the glass.
If you have power windows, pop out the part of the armrest that has the switches in it. Remove the screw under there. Unplug the wiring from the switches.
Then, lift the door pane straight up about 1 inch then remove it. These panels have tabs that slide down into pockets, they are not like older vehicles that use the push-in clips.
Reverse procedure to reinstall. Just be sure to put the lock button up thru the panel before pushing it back down or it will be hard to unlock the door.
Old Feb 8, 2007 | 05:37 PM
tdister's Avatar
tdister
https://www.ford-trucks.com/article/...ion_notes.html
This article covers what LxMan1 covered and then some, with a few pics as well (in case you are better with pics than words). It's for replacing the speakers but might help a little. Pretty sure the '02 is the same basic style. Good luck.
I found a thin knife to be handy for getting the lock button lined back up to come up through the panel. I was getting kinda frustrated before using it. Hmm, I just realized rolling down the window might have helped too, but that wasn't an option for me at the time
