Need step by step instruction!
Old Feb 7, 2007 | 05:58 PM
UGA33's Avatar
UGA33
got 5in cat back on 06 F-250. I want the cat off but want to be able to put it back on if it needs to go back to the dealer for warranty work. The system is stock from the turbo to the cat. What steps are needed next? Will the mbrp 4in cat delete test pipe fit the stock exhaust? Will someone have to custom cut a 3 1/2in pipe to fit it? What do i do?
Old Feb 7, 2007 | 08:32 PM
olfordsnstone's Avatar
olfordsnstone
I would try the the supplier for info. I'm sure they would be more than willing to give you the solution. If you get an answer, please post up, as I am considering doing the same mod.
