Sponsored by: Real Truck
Manual Locking Hubs
Old Feb 7, 2007 | 01:42 PM
moomba2002's Avatar
moomba2002
Manual Locking Hubs
I have a 99 Ford F350 Dually and one of the front locking hubs has gone bad. I wanted to replace it with a Warn hub but they all say they will not fit a Dually. Do any of you know what the difference between the dually locking hub is and the single wheel becuase no one else seems to know. Thanks.
Old Feb 7, 2007 | 02:00 PM
redford's Avatar
redford
FTE Leadership Emeritus
That is correct, Warn does not make a hub for the F-250 DRW.
I think you have to go to Mile Marker to get manual hubs.
Old Feb 8, 2007 | 09:17 AM
steveg748's Avatar
steveg748
Moomba
I have a 2000 f-350 4x4 dually long bed and I purchased my hub at carquest and it works better that the original.
steveg748
Old Feb 8, 2007 | 10:27 AM
Gription's Avatar
Gription
Take a Look at Dynatrac hubs these things will save you lots of $$ in the long run. I think the problem with your 99 is that its the only year the Hub Adapters were not machined all the way through from Ford.
Old Feb 8, 2007 | 10:33 AM
moomba2002's Avatar
moomba2002
Thanks for the help. I talked with Mile Marker and they said they had a set that would work as well. I ordered a set and hopefully they will fit, I will let you know.
Old Feb 8, 2007 | 11:29 AM
DFord79's Avatar
DFord79
Your on the right track. I am surpised you had trouble finding a hub. That is not an issue with any Ford HUB I have heard of. Everyone has them.
