Bronco II Ford Bronco II
Duraspark conversion - Distributer cap woes
Old Feb 7, 2007 | 09:14 AM
dnachristen's Avatar
dnachristen
Hello all...
I'm in process of my duraspark conversion...
I followed the instructions to the tee for the conversion. I bought the distributer at Schucks (302691) for a 79 pinto. It's the same exact part listed at Napa (48-2691).
No one can seem to find the correct cap and rotor for this disty... I'm about to pull my hair out!!
I would use my original cap from my 85 broncoII but it seems it needs to be smaller. The threaded holes for the cap screws are about 1/2" off from where they need to be.
Any clues?
Old Feb 7, 2007 | 09:51 AM
kernel-panic's Avatar
kernel-panic
These? :
Parts are listed on Shuck's/Kragen/Checker/Advance online store....
http://www.partsamerica.com/ProductL...Cap%2fCap+Kits
And on NAPA's online store....
http://www.napaonline.com/masterpage...d=1&SubCatId=1
And AutoZone's online store....
http://www.autozone.com/servlet/UiBr...+And+Rotor+Kit
Old Feb 7, 2007 | 10:13 AM
dnachristen
I think I found what I needed.. I did a bit more research, and you need the cap adapter ring. It converts it from the standard cap, to the half height one.
Thanks for your help!
