What happens if ... ?
Old Feb 6, 2007 | 11:26 PM
caseys's Avatar
caseys
Question What happens if ... ?
xxxxxxxxxx
Old Feb 7, 2007 | 12:41 AM
fastfordmobile's Avatar
fastfordmobile
I would pull the fuse to the cruise control and make the entire circuit dead
Old Feb 7, 2007 | 12:43 AM
caseys's Avatar
caseys
xxxxxxxxxx
Old Feb 7, 2007 | 08:34 AM
MisterCMK's Avatar
MisterCMK
It should just kill the cruise. The dealerships were disconnecting that switch when the recall first started and they didn't have parts yet.
Old Feb 7, 2007 | 11:08 AM
caseys's Avatar
caseys
xxxxxxxxxx
Old Feb 7, 2007 | 09:41 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Just unplug the switch. Wrap some electrical tape around it to prevent it from shorting out or anything and tuck it away from the switch. The only thing this will do is prevent the cruise from working.
If you pull the fuse for the cruise control, several other systems will be affected as well.
You will not need the new fused wiring harness, as the new design switch likely won't ever leak, and if it does it's designed not to short out the electrical contacts.
Good luck
Old Feb 7, 2007 | 10:26 PM
caseys's Avatar
caseys
xxxxxxxxxx
Old Feb 7, 2007 | 11:03 PM
edgl's Avatar
edgl
I changed the cruise control switch on the master cylinder on my 2002 Mazda, with a new metal one from Ford. It came with a short jumper lead that plugs into the new switch and the truck wiring. It was about $14.00 for the kit. All you need to do is unplug the connector on the Master cylinder to kill the cruise, and not worry about a fire.
Old Feb 7, 2007 | 11:16 PM
caseys's Avatar
caseys
xxxxxxxxxx
Old Feb 8, 2007 | 09:44 PM
MazdaRangerGuyInSTL
You can purchase it from any ford dealer, but it may cost a few bucks more. I don't know about Rockauto, but the kit Ford sells includes the new design switch and a non-fused wiring harness to adapt the old plug into the new plug of the new sensor.
Caseys, being that fluid has already gotten into the harness connector, I HIGHLY recommend that instead of just plugging in the new harness, you cut the connectors off both harnesses and solder the wires together.
The FUSED wiring harness is only to install on the old switch if it isn't leaking. That way if it shorts out the fuse will blow instead of burning down the truck. When ford issued this recall, they didn't care about the switches leaking, they just cared about the fire hazard.
Old Feb 8, 2007 | 10:33 PM
caseys's Avatar
caseys
xxxxxxxxxx
caseys
May 28, 2012 09:28 AM
caseys
83
Oct 19, 2011 12:46 PM
caseys
15
Mar 11, 2007 11:02 PM
casey38boost
Mar 21, 2006 07:06 PM
caseys
Jun 8, 2005 11:31 AM
