Trans Help
Old Feb 6, 2007 | 08:39 PM
WV96FORD's Avatar
WV96FORD
Trans Help
I have '96 302 Automatic and the trans started shifting hard about a week ago. If i am on the throttle it wont change gears until i let outta the throttle to allow it to change and when i get on a hill the trans cant decide what gear it wants it will go to 3rd then 4th and instantly go back to 3rd. any ideas on what could be wrong? hopefully a sensor of some kind and not a trans..
Old Feb 6, 2007 | 10:36 PM
subford's Avatar
subford
It could be the TPS or VSS (or its wiring) in the sensor line and also the PSOM in the module line.
How is the speedometer doing?
TPS - Throttle Position Sensor
VSS - Vehicle Speed Sensor or signal
PSOM - Programmable Speedometer/Odometer Module
Old Feb 6, 2007 | 11:41 PM
Ponyracer's Avatar
Ponyracer
The MLP sensor (Transmission Range Sensor) also can cause this and not set codes.
Get the codes pulled if there are any and let us know. Also I am assuming that this is a 4R70W but there is the rare 5.0/E4OD combination so we need to kow that also.
Old Feb 7, 2007 | 11:11 AM
WV96FORD's Avatar
WV96FORD
subford,
the speedo doesnt work and that is another issue i am having. it hasnt worked for a while now and i cant seem to get any answers on what is the problem. i have replaced the vss twice thinking i got a bad one and that didnt work. i took it to a garage and the replaced an abs sensor aswell and that didnt work. they said they had no idea what was wrong but didnt tell me what codes it threw. as i said before the trans wasnt acting like this until about a week ago so i just kinda wrote it off that it was a different problem. Another weird thing is it snowed the other day and i went out playing that nite and the next day the speedo worked all day. the next morning it was dead again so it has got me perplexed.
Ponyracer,
i am not sure what trans it is i will check on that and let you know. the trans code inside the door is U. and i am gonna try to get the codes ran this week so i can try and get this problem resolved.
Thanks a lot for all the help
Old Feb 7, 2007 | 12:00 PM
subford's Avatar
subford
"U"= 4R70W transmission.
Your PSOM module is bad and you need to replace it or the wiring is bad between the VSS and the PSOM.
EDIT:
By the way you do not have an ABS Sensor, the VSS takes care of both jobs on your 96.
Old Feb 7, 2007 | 12:24 PM
subford's Avatar
subford
By the way for your information all PSOMs from 1992 through 1996 are the same, you may be able to get one from about $30.00 at a salvage yard but can not buy one from an Auto Parts store or from Ford.
Ford will install one but it will cost you about $450.00.
Old Feb 7, 2007 | 02:43 PM
WV96FORD's Avatar
WV96FORD
Thanks for all the help i really appreciate it..i am usually pretty good at fixing stuff on my truck but when it comes to electrical and codes some of the **** they do is almost impossible to find unless you really know what your lookin for...this will narrow it down and i should be able to figure it out now. again thanks for all the help and information
