1978 - 1996 Big Bronco
alternator replacement
Old Dec 13, 2002 | 08:50 PM
NJbronco138's Avatar
NJbronco138
Hi, I'm new to the board. I've only had My Bronco since May, so I'm new to working on it. I need a new alternator. Is it hard to change the alternator? Its a 91 with a 5.8. I was told all I needed to do was pull up the belt tensioner with a wrench on the bolt, disconnect the wires and the two bolts holding the alternator and replace. Is that right? Thanks Marcus
Old Dec 13, 2002 | 10:41 PM
screwy's Avatar
screwy
not sure on 91s i wouldent think it has a big difference but mine was that easy i think it had 3 bolts tho, no biggy
96 Bronco, Eddie Bauer, 351w
Old Dec 13, 2002 | 10:55 PM
fcarruth's Avatar
fcarruth
I did my 89 last month and I think that they are very similiar. On mine, take the belt off of the pulley, remove 1 long bolt from the front side of the engine and then a smaller one one the top of the alternator that kind of removes from the back side of the bracket. Remove the 2 connectors and work it off of the bracket.
It took me about 30 minutes to do this and that was about 10 minutes figuring out how to get it loose from the bracket.
This may not make much sense but before you put the new one on, get your pliers and put one jaw on the bracket of the lower bolt area and the other jaw on the gromet looking thing and tweak down on it a little. What this does is make it easier to put the new one back in without beating it too hard.
Sorry for being long winded.
Happy Holidays ! :-X12
Old Dec 14, 2002 | 01:19 PM
NJbronco138
thanks guys. I popped the old one out and the new on in. Two bolts and about 20 minutes. Everything looks pretty good now
Old Dec 14, 2002 | 08:05 PM
tite4x4's Avatar
tite4x4
