99 Expedition wont start please help
Old Feb 6, 2007 | 04:15 PM
BigAss76's Avatar
BigAss76
Couple of days ago wipers stopped working in the middle of a downpour. I get home and the 4x4 light starts blinking, next day, I go to the store shut it off and the guages stay on. Now it doesnt start, any clues what i should check. Let em know. Thanks in advance, Josh
Old Feb 6, 2007 | 04:43 PM
l-m tech's Avatar
l-m tech
sounds like the fuse box is full of water causing the power to short over to other circuits.have you had a windsheild put in it lately. usually a skip in the sealer causes the problem you are having
Old Feb 6, 2007 | 08:20 PM
BigAss76's Avatar
BigAss76
no windshield since I have had it but then again thats only about two months. I dont know if the temp has anything to do with it, but I am on long island ny, and its freezing out. Could that be it, i checked all of the fuses none are out. Also now when i turn the key to the on position all of the gauges go to full ie. 6000rpm gas full, temp hot, battery overfull etc... Does that make the diagnosis easier. I think I will be able to fix whatever it is but I am no good with diagnosing the problem
Old Feb 6, 2007 | 09:14 PM
kailor's Avatar
kailor
Research the GEM module.
