Aod To C6 Swap
Old Feb 6, 2007 | 02:08 PM
WHATEVER's Avatar
WHATEVER
Aod To C6 Swap
I Have A '91 F150 And Have Swapped The Original Aod For A C6. I Use This Truck To Pull A Landscape Trailer 90% Of The Time. The Problem Is That After Having The Swap Done I Only Have Drive And 2nd Gear Because The Shifter Column Will Not Travel Far Enough To Go Into Low Gear. I Have Tried To Adjust It At The Trans But No Luck. The Shop That Swapped It Did Not Know How To Correct It So I Need Help. Any Suggestions Would Be Greatly Appreciated.
Old Feb 6, 2007 | 09:51 PM
stuart1's Avatar
stuart1
You will probably have to Mickey Duck an arm to fit it.
You can drill another hole in the arm, bolt a piece of flat steel to it and drill another hole accordingly.
