Brake controller harness
Old Feb 6, 2007 | 01:11 PM
f350peter's Avatar
f350peter
This might seem like a stupid question, but I have to ask. Will the brake controller harness/plug from a 2004 F150 work on a 2002 F350? I kept the brake controller wiring when I traded in my 150, and figured I’d ask before I get a new plug/harness. It’s been too cold to crawl up under the dash and look at the plug.
Thanks all,
Peter
Old Feb 6, 2007 | 01:53 PM
Steina's Avatar
Steina
CO River Rat
The under-dash connector for my '02 & '04 Explorers were the same, so I would think you're good-to-go.
Steve
Old Feb 12, 2007 | 07:56 PM
Greywolf's Avatar
Greywolf
Since I've had to install more than one brake controller in the last six months, and troubleshoot many others, on all kinds of brands - I will say this:
FORD is outstanding for putting the under dash connector in place, and where it can be got at. (Except in F150's).
GM has connectors too - but they stuff them up into an area under the dash that cannot be got to, so they might just as well not be there at all...
Mercedes SUV's are an outright mystery... They won't release any info to us at all.
Any time I see anything but an F250 or above roll in, I know I'm looking at a long day.
Old Feb 12, 2007 | 10:18 PM
cub129's Avatar
cub129
Greywolf,
The pre-wired harness in my '06 F-150 is right there under the dash, spotted it easily in about 30 sec. and IMHO not hard to get to either.
I agree, Fords are easy to wire for controllers.
Old Feb 12, 2007 | 10:41 PM
Steina's Avatar
Steina
CO River Rat
Wolfie -
Apparently you haven't done any Gen III Explorers. Ford cleverly tied the connector up behind the glovebox; not sure what the reasoning on THAT was.
Steve
Old Feb 13, 2007 | 03:35 AM
mjsparky363's Avatar
mjsparky363
controller harness
don't know what controler you have, but prodigy says that some years 250/350 need a seperate ground.? otherwise it should fit.
Old Feb 13, 2007 | 08:10 PM
Greywolf's Avatar
Greywolf
Originally Posted by Steina
Wolfie -
Steve
HEY! Thanks for the heads up.
And yeah - 90% of the problems I have seen with controllers are directly GROUND related. Without a clean ground path - there is no path for current to flow. Cut and dried.
Old Feb 15, 2007 | 01:35 PM
f350peter's Avatar
f350peter
I've got a Voyager Controller.
Old Feb 22, 2007 | 05:02 PM
dhag911's Avatar
dhag911
Thats because you arent suppose to tow with a chevy
Old Feb 22, 2007 | 08:22 PM
Greywolf's Avatar
Greywolf
A brake controller, when you get right to the nuts and bolts of it - is nothing more than a box that recieves a signal from the brake pedal that allows an adjustable amount of electricity to be sent to the trailer brakes by means of a potentiometer (simple variable resistor) with an "OH CRAP!" switch installed to allow you to slam on the trailer brakes full blast.
That's all it is...
