transfer case
Old Feb 5, 2007 | 09:37 PM
ZonaNavyStar's Avatar
ZonaNavyStar
transfer case
Which transfer case would a 1995 F-150 w/ 351 E4OD with the automotic hubs and automatic 4x4 shift (shift on the fly I think they advertise it as) have? Haynes made it sound like just one has the electric option, but how do you confirm? Thanks.
Old Feb 5, 2007 | 10:56 PM
Tdvjensen's Avatar
Tdvjensen
Most likely the borg warner 1356 t-case because the earlier 208 were only available in manual shift.
Old Feb 7, 2007 | 09:43 PM
dhag911's Avatar
dhag911
you can look at the transfer case there should be a tag on one of the outer bolts. But if you or any previous owner never changed it then it would have to be the BW-1356.
Are you haveing problems with it or are you just wondering
Old Feb 7, 2007 | 09:47 PM
jyccustoms's Avatar
jyccustoms
the only one u can have that year is a 1356 borg warner.
Old Feb 11, 2007 | 01:01 AM
ZonaNavyStar
Thanks for the help. It is the 13-56. I was wondering so I could get the right amount of ATF to change the fluid. I figure I might as well change the fluid while I replace the U-joints and have the slip yoke out anyway. Job is done, I got the right amount of fluid and it seems to work great! Thanks again
Old Feb 11, 2007 | 01:25 AM
jyccustoms's Avatar
jyccustoms
no problem,i work at a salvage yard so our computer sys.lets me look up almost anything.shows id #'s and the exact interchange on the parts
