F150 Cold Start Help
Old Feb 5, 2007 | 09:35 PM
natewoz's Avatar
natewoz
Hi,
The last week here it finally feels like winter in Northern Minnesota. Daytime temps are -10 to -18 and dip to -30 at night. I'm having issues getting my truck to start. It's never failed me on warm days when it is -5 or higher, but below that it is a crapshoot. If I have the block heater plugged in, there are no problems, but when I go somewhere that doesn't have plug-ins I have been stranded even when it was -7.
You guys know of anything to check in particular that would help? I'll try to get codes tomorrow, the PCM will be full of misfire codes since I havn't been able to start it the last 4 times I tried. I had to get pulled home by a freind this afternoon.
I pretty much have to remidy this situation or try and sell the truck to get something newer, probably a 99+ GM 1/2 ton 5.3 or a 5.4 Superduty.
Thanks
Old Feb 6, 2007 | 08:36 AM
Redcat Diesel's Avatar
Redcat Diesel
Hey nate, Does your truck crank but not fire? Or will it not crank? I have seen a few vehicles exhibit similar symptoms that were eventually traced to the module or PCM.My experience is not limited to Fords.The first 1 was on a U.S. Postal truck about 25 years ago.Below 5 degrees or so it would not fire unless the ignition module was warmed with a heat gun.Replacing the module fixed it.After that whenever I get a vehicle with those symptoms I try warming the module.It has helped to repair a few since.Hope this helps.
Old Feb 6, 2007 | 05:08 PM
natewoz's Avatar
natewoz
It cranks just fine, It will fire a cylendar here and there and sputter but doesn't start.
Old Feb 6, 2007 | 05:34 PM
DWB78F250's Avatar
DWB78F250
My 1995 is hard to start also I turn the key on and off 2 or 3 times before trying to turn it over it seems to help when it's below zero.
Old Feb 6, 2007 | 06:19 PM
weeds's Avatar
weeds
Yeah, my '95 sounded like a pig trying to start today. Temp was somewhere between 0-2. On a side note, whenever you pulled the codes, what did you find? Mine was throwing the check engine light this morning and said bad EGR, and something about TOT (mechanic didn't get to trace it, but said it was something with transmission). We chalked the codes up to the cold weather, and the fact that's it's been sitting for a couple days.
Old Feb 6, 2007 | 11:23 PM
Redcat Diesel
Do you have access to a scan tool? If you can, try to read the codes when it won't start.If it won't communicate with the scan tool it's not going to fire the plugs.Something else to try is checking the fuel pressure when it won't start.
Old Feb 8, 2007 | 05:17 PM
natewoz's Avatar
natewoz
Ok, it finally got warm enough and I had free time to pull codes. Here goes
511- Bad PCM - I'm thinking this is because of my Diablo Delta chip.
17 - Throttle stop to low on 1.9L and 2.5L engines???????? I have no clue here, help me out please!
33 + 34 - EGR EVR not responding/ opening etc. This might be a or "the" problem.
I've had a hard time getting a consistant definition on the codes, especially 33, 34. Everywhere I look is a little different.
Edit to add: Code 33 come on on both KOEO and KOER.
