comprehensive 2.3 info
Old Feb 13, 2007 | 02:26 PM
mattri's Avatar
mattri
Was there any difference between the single and dual plug head other than the plugs themselves? Chamber size, port design etc?
Old Feb 13, 2007 | 07:51 PM
Old Rob's Avatar
Old Rob
The intake ports, combustion chamber and valves are different. The dual plug heads cannot use any of the older intake manifolds.
Old Feb 13, 2007 | 09:49 PM
mattri's Avatar
mattri
Sorry I wasn't specific, what are the differences in chamber size and valves? When were the dual heads introduced? What were the cam specs for the respective heads?
Old Mar 12, 2007 | 11:03 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
The SVO Mustang had different HP ratings then the Turbo Coupe
Mustang SVO horsepower, torque ratings
and performance by year
1984
HP 175 @ 4400 RPM Torque 210 @ 3000 RPM
0-60 in 7.7 seconds, ¼ mile 15.8 seconds
1985
0-60 in 7.3 seconds, ¼ mile 15.4 seconds
1985½
HP 200 @ 5000 RPM Torque 240 @ 3000 RPM
1986
at least according to the SVO Owners of America.
Old Mar 20, 2007 | 08:09 PM
mattri's Avatar
mattri
Thanks for all the replies, this is, I believe a motor with great potential, glad to see others interested in it as well.
Old Mar 26, 2007 | 10:14 PM
bryrykim's Avatar
bryrykim
ok now i have a question for this guy does the wiring change much from the 86 2.3 4 plug to the 89 2.3 with 8 plugs you see i just pulled the 89 motor and i want to put it in my 86 i have the wiring harness and the comp but do i really have to change all of that or can i just change portionsof the harness
Old Apr 4, 2007 | 04:29 PM
460429_freak's Avatar
460429_freak
if my memory serves me right....
there was
round port
d port
and oval port heads
I raced these for a few years in stock form they can turn 6800 all night
with a few mods they can run 10000 rpm all night
there are so many aftermarket part for these it is crazy (like a 350 for chevy)
you need to list what you are doing with this motor there is power in the heads of these motor's a little porting polishing and shaving the head and they will scream!!
bryrykim I have heard of people just not hooking up the other 4 plugs and just hooking up the wiring harness the head is the only differnce on this motor.
Old Apr 5, 2007 | 12:15 AM
TLyttle's Avatar
TLyttle
6800rpm bone stock? The tach in my Rustang redlines at under 5 grand; do I ignore that, and just let it wind? I am in the throes of deciding whether to rebuild the 2.3, or to just pitch in the 3.8 I have in the shop and get on with it... If I can get a reliable six grand out of it with power all the way to there, I will do the 2.3.
Oh, dear, decisions, decisions...
Old Apr 5, 2007 | 12:31 PM
460429_freak
yep 6500 to 6800 all I had in it was a stock roller cam out of a 93 block a adjustable cam gear... and a carb of a 400 m... what you have to do is get a pinto intake take the spacer off it and get a thick gasket you can bolt a motocraft or a holley 350/500 cfm carb on it it willl screaaaaaaaammmmmmm. for a 4 banger..that's why I want a pinto that is not rusted and has a clear title I have a few but a rust bucket....
Old Apr 5, 2007 | 07:53 PM
TLyttle's Avatar
TLyttle
Hah. Good info, now all I gotta find is a dead Pinto...
Being old, I rely on carbs, simply because I understand them. I know there are lots of guys who will tell me that FI is the only way to go, but I don't feel I have the time to learn a "new" system...
If I do go carbs, I will likely have a new intake cast up to handle the pair of 2" SUs on there; I really understand SUs!
Decisions, decisions...
Old Apr 13, 2007 | 01:35 PM
tulenut's Avatar
tulenut
Question 2.3 parts interchange
Have I got a question.Does anybody out there know if the ford LSG423 industrial engine(2.3L also),uses any of the same parts as the auto and trucks do.Thanks.
Old May 4, 2007 | 07:11 PM
tulenut's Avatar
tulenut
TigerDan,heh do u know if the 2.3l (lsg423 industrial) is the same as the street versions of the 2,3l.I need to know parts interchangeability.Thanks.
Old May 4, 2007 | 07:18 PM
  #28
TigerDan's Avatar
TigerDan
I've found very little info on the 2.3 industrial engine. As far as I know it's basically the same engine, but I wouldn't swear to it...
Old May 6, 2007 | 02:56 PM
  #29
mattri's Avatar
mattri
Interesting, what were the industrial engines used for, I would assume pumps generators etc? Where would one find them?
Old May 7, 2007 | 11:27 PM
  #30
darrin1999's Avatar
darrin1999
is the 2.3 in a ford tempo the same as a 2.3 in a pinto? or are they like the 351s- completely different except for displacement?
