Sponsored by: Real Truck
noise in front end
Old Feb 5, 2007 | 07:41 PM
fireball318's Avatar
fireball318
noise in front end
my 03 crew 4x4 has a new noise. when i hit a bump it sounds like something is loose . sounds like it is coming from driver side front wheel. also you can feel something bumping the floor when you here this sound. is it the ball joints? anybody know?
Old Feb 5, 2007 | 08:08 PM
lemdog's Avatar
lemdog
Thumbs up
It is your ball joints, my 99 was doing the same thing, put new ball joints in and the problem is gone. Good Luck!
Old Feb 6, 2007 | 07:43 PM
st3ib's Avatar
st3ib
mine was doing the same thing and it was the swaybar end link bushings. to check it, grab hold of the swaybar at one end and see in you can move it side to side.
Old Feb 6, 2007 | 08:27 PM
jim6liter's Avatar
jim6liter
Pull the carpet back a little and there is a whole where the body mounts are.Crank those down tight.Possibly a little loose.Seen that before.My .02
Old Feb 6, 2007 | 08:33 PM
fireball318
thanks i give the swaybar a shake if not new ball joints. and check the body mounts. thanks again.
Old Feb 6, 2007 | 08:36 PM
marcs724's Avatar
marcs724
All three of the super duties I have had made that noise. All three times its been the sway bar bushings. Not the end links, but the bushings where the sway bar attaches to the axles. Its a very cheap easy fix and i would definetly start there. In my experience ball joints have to be VERY shot and borderline dangerous to even drive to make that kind of noise. Oh, the other thing is you can't really tell if they are shot or not. There usually isn't any play in the sway bar, and they will look fine, but all three times I've replaced that first and no more noise. Hope that helps
Old Feb 7, 2007 | 09:34 PM
fireball318
marcs724 thanks for the info. If I ever get my truck home I will check sway bushings. only have 45000 miles on rig.
