Help Needed Locating Cam Position Sensor
Old Feb 5, 2007 | 07:22 PM
Jager's Avatar
Jager
I'm in need of help locating my cam position sensor. If anyone can help me locate it I would be greatfull. I know that it's the problem because I'm getting a code for it.
Thanks for any help!
Old Feb 5, 2007 | 07:45 PM
johnguc's Avatar
johnguc
Its on the front slightly passenger side of the engine just above the balancer pulley.
It has the timing tab on it.
Old Feb 5, 2007 | 08:48 PM
IDMooseMan's Avatar
IDMooseMan
Here is the easiest way I can think of to get to the CPS:
  1. Have your "working on the truck and I don't care what I look like" clothes on.
  2. Make sure you are wearing eye protection and work gloves.
  3. If you remove the serpentine belt from the bottom pulleys, your visual field is enhanced. From the front of your truck, lie down on your back, grab the bottom edge of your bumper, and pull your self under the truck until you see your pulleys.
  4. Near the crankshaft pulley, you'll see an electrical connection. That's the CPS.
I hope this helps.
It took me 10 minutes of repositioning myself under the truck to finally decide to remove the belt from the lower pulleys. Once the belt was out of the way, removal and installation took 5 minutes. It might have gone faster, but I had back surgery in March and was taking it easy on myself.
Old Feb 5, 2007 | 10:54 PM
Jerme's Avatar
Jerme
And be careful when unbolting it, some of them are on there tight and is easy to round off the edges. Mine was one of them.
Old Feb 6, 2007 | 02:42 PM
rockyrider's Avatar
rockyrider
The site below is for an 02, but it the same.
http://guzzle.rbmicro.com/cps.html
Old Feb 6, 2007 | 09:23 PM
IDMooseMan's Avatar
IDMooseMan
Jager, any luck? Did you find it?
