72 F250 window replacement
Old Feb 5, 2007 | 12:52 PM
loeswk's Avatar
loeswk
Question 72 F250 window replacement
Some kids shattered my driver side window the other night and I am struggling to replace it.
I picked up a window at the wrecker, but I cant' figure out what order to use to reassemble the door.
I am trying to put the window into the door first, then replace the wing window assembly, then add the regulator assembly.
I just can't seem to find clearence for everything.
Does anyone have suggestions for what to do first? Any "tricks" I should be aware of?
Old Feb 5, 2007 | 01:28 PM
Conanski's Avatar
Conanski
I think you need to have the regulator assembly in place before installing anything else. If it is put together like the 87-96 version, the track on the bottom of the main window will slide on/off the regulator arm, so put this in next with the crank down most of the way, and then the vent window and guide is put in place last.
Old Feb 5, 2007 | 02:02 PM
loeswk's Avatar
loeswk
Thanks Paul !!!
I'll give it a shot....
Old Feb 5, 2007 | 02:36 PM
quicklook2's Avatar
quicklook2
do you have a 1972 or a 1992 truck?
if you have a 1972 than more help would be found in that forum.
Old Feb 5, 2007 | 02:48 PM
loeswk's Avatar
loeswk
72 - I'll try the other forum.
