2002 Spark Plugs
Old Feb 5, 2007 | 08:39 AM
afsigma21's Avatar
afsigma21
2002 Spark Plugs
OK, I know there are probably a ton of threads on this subject, but I am not that good at digging them out.
I just picked up my Ranger, 2002 XLT Supercadb with 4.0 2wd. I want to replace the plugs because it doesnt run real smooth at idle. At 1500 rpms and up it is smooth as silk, but at idle, which runs at about 700rpm on the tach, it "bumps" to describe it best. Besides, I just got it and want to "freshen it up" so to speak!
So, What do people use? The Expy forums say Motorcraft platinum, ONLY. I used NGK Vpowers on my Dakota with great results, and my old ASTRO ran awesome on splitfires.
Anyone got an opinion?? (LOL)
Old Feb 5, 2007 | 10:04 AM
pgw85706's Avatar
pgw85706
Motorcraft or Autolite DP. I am a NGK fan for my euro cars, but for the truck I went autolite and am very pleased.
https://www.ford-trucks.com/forums/1...and-wires.html
Old Feb 5, 2007 | 11:03 AM
rubydist's Avatar
rubydist
AND - make sure you get the right plugs!!! A lot of the plug manufacturers list the plugs for the 4.0 ohv and the 4.0 sohc as being the same - THIS IS NOT CORRECT! If you put ohv plugs in the sohc it will not run right - it will ping, etc. because the plug reach is incorrect.
Stock plugs are Motorcraft AGSF34FP, which crosses to Autolite 5144 (different suffixes for copper, platinum, double platinum, etc.)
Old Feb 5, 2007 | 12:10 PM
pgw85706's Avatar
pgw85706
Autolite had a rebate good for $1.25/plug last year. You may want to check to see if it was extended.
http://www.autolite.com/rebate/save24.php
Old Feb 5, 2007 | 12:20 PM
OSin86's Avatar
OSin86
Stick with NGK.
I'm running NGK in my 4.0 OHC and love them. The stock Motocraft plugs were highly disappointing. On average they eroded 22 thousands in 80k. That's a lot for a platinum.
cavman35
1997 - 2003 F150
Nov 17, 2022 06:13 PM
green 69
Feb 27, 2012 01:49 PM
goodwrench
67
Oct 24, 2007 09:42 PM
2002f2507.3LPS
33
Oct 1, 2007 04:56 PM
94 aero
Aerostar
Feb 28, 2001 02:15 AM
