250 / 350 spindles
Are the spindles the same for a 80-86 F250 as an F350. Are they different spindles on a 2wd dually than srw? Thanks.
1980/82's use 4 different sets, depending on GVW.
1983/85's use 3 different sets, weight again is a factor as is the build date.
Prior to 1986, some spindles are F250 only, some fit F250/350.
1986 This year only uses one set. F250/350 .. No dif if SRW or DRW.
1987/89 These 3 years use one set. F250/350 .. see ^^^^^^above.
